misfire
Old Apr 20, 2006 | 02:51 PM
elvis12's Avatar
Default misfire
Hello,
I have a 1998 a4 1.8t with a tap-1 stage 2 chip, custom exaust, k and n intake (no air box).
and all of a sudden with no warning, the car started to run rough, and had a loss of power.
when i pluged in the code reader, it gave me 2 codes, random misfire, and misfire on cly #3.
Here is what i have done.
i moved around the coil packs, to see if the miss followed the pack. it did not, still on #3
i pulled the injector rail to see if they were firing, they were.
i also moved the injectors around to see if the miss followed...it did not...still on #3
i did a compresion test, all around 125 psi....good for 80k
and yes i replaced the plug...
tap 1 is sending me a test computer
anyone have any other ideas??????
thank you in advance.....E
Old Apr 20, 2006 | 02:54 PM
techbod's Avatar
Default RE: misfire
codes please
Old Apr 20, 2006 | 03:24 PM
elvis12's Avatar
Default RE: misfire
codes
16684 random
16687 miss on cly #3
and only after i started to do trubleshooting
16502 coolant temp (on and off)
Old Apr 20, 2006 | 03:26 PM
Russian Rings's Avatar
Default RE: misfire
i have the same problem going on right now..but its my second cylinder and i have 100k miles now..i dont have a scan tool so i brought it to a 3rd mechanic who seemed confident
Old Apr 20, 2006 | 03:30 PM
elvis12's Avatar
Default RE: misfire
well good luck to you,
you can be shure i will post the result with my car....hopefuly that might help you...
i am convinced that it is the ecu, or in the wire harnes leading to it...
we will see when the test computer comes in..
E
Old Apr 20, 2006 | 03:35 PM
techbod's Avatar
Default RE: misfire
16804 cat below threshold
16684 random misfire that's normal
166502 now that's your problem a lose wire to ground signal obstruction, thermostat sticking or wiring problem
Old Apr 20, 2006 | 04:29 PM
elvis12's Avatar
Default RE: misfire
ok, i can accept that,
but when the problem first poped up that 16502 code was never there, even after a 15mile limp home???????
E
Old Apr 22, 2006 | 02:11 PM
dankhound's Avatar
Default RE: misfire
Bad ignition control moudle on air box.
Old Apr 22, 2006 | 02:15 PM
elvis12's Avatar
Default RE: misfire
that is what i am thinking, too,
Old Apr 23, 2006 | 02:08 AM
acetrebo's Avatar
Default RE: misfire
I agree, i had the same issue on cyl. 2.
Replace the ignition module on top of the air box.
Russ Heinrichs
Aug 18, 2021 12:39 PM
dorkfish
May 6, 2013 09:58 AM
slow_key
Sep 23, 2010 08:25 AM
themahr
Mar 31, 2009 03:50 PM
