misfire problem, please help me out
Old Oct 14, 2007 | 06:16 PM
a4Fan1.8t's Avatar
Default misfire problem, please help me out
Got the revo chip installed about a week ago and I noticed that I was getting a few misfires. At first there were a lot when you got on it and they could continue from about 3000-4500 where it would finally clean it self up. I went to my local shop and had the guy drive it and he agreed with me that it was misfires. I changed the plugs to NGK(i forget the number but it's one temp cooler then stock) and set the gap to .028. This really helped the problem but didn't competently fix it. I still get small misfires that are not enough to get the cel to flash and they don't last long or happen every time you accelerate. When I was changing the plugs I noticed that the plastic boot on at least one coilpack maybe two was cracked near the bottom and they look original. I ordered the hitachi E packs from ecs hoping that this will fix the problem and i'm going to replace all 4. Could there be any other causes for small misfires like this? It's a 2000 1.8t btw.
Old Oct 14, 2007 | 06:37 PM
hiwords's Avatar
Default RE: misfire problem, please help me out
well the problem seems to be diminishing as u fix things so looks like ur going in the right direction. check back after u change the packs
Old Oct 14, 2007 | 06:41 PM
auditech79's Avatar
I can't remember if the 2000 model has an ICM (ignition control module) or not, it would be bolted to the top of the air box if it were there. That would be your problem, not your coil packs.
Old Oct 14, 2007 | 06:44 PM
hiwords's Avatar
shame on u auditech79. ur supposed to kno it dammit lol
Old Oct 14, 2007 | 06:48 PM
viper9821's Avatar
I'm pretty sure 2000+ don't have icm.
Old Oct 14, 2007 | 06:49 PM
auditech79's Avatar
Im not required to know all that s***! I only have so much memory i can store in my brain, thats why we have repair manuals.
Old Oct 15, 2007 | 12:33 AM
david9999's Avatar
No ICM on 2000+
Old Oct 17, 2007 | 05:31 PM
Brandon2000s4's Avatar
Do the 2000 S4's have an ICM?
Old Oct 17, 2007 | 05:34 PM
acetrebo's Avatar
Replacing all 4 coilpacks should fix your problems. It happens a lot after cars are chipped for some reason. I will not speculate as to why, but I've just seen many similar posts to yours.
shongill
S4
Aug 13, 2013 03:37 PM
CYLax
Jun 30, 2010 07:19 PM
Nags
Jun 24, 2010 04:37 PM
mrbloink
Jun 12, 2009 04:42 PM
markupton
Mar 29, 2005 01:58 PM
