misfiring
Old Dec 18, 2005 | 01:41 AM
tontod's Avatar
Default misfiring
I just took a drive with a friend a little while ago, around 5k rpm the car starts misfiring badly and feels like a chipped k03. In 1st and 2nd gear it seems fine, then in the 3rd gear, it feels like I'm not getting much boost and seems like a big power loss. Unfortunately, I dont have a boost gauge installed yet. I recently got a ko4 (k04-015 software) installed, also have a high flow cat, borla exhaust, ported/polished manifold, 710N DV, 5 bar fpr. I drove the car hard just after getting the k04 installed, and there was no misfiring then. I have been driving conservatively the last few days because I want to see the difference in mpg from when I drive hard. After filling up earlier today, I drove hard and the misfiring. Anyone in the Boston area that has a VAG that I could borrow to see if there are any codes? I guess without a VAG its hard to tell what could be wrong?
Old Dec 18, 2005 | 04:06 AM
tontod's Avatar
Default RE: misfiring
Any ideas? I got the spark plugs replaced - they are ngk bkr7e along with the k04 on 12/9.
Old Dec 18, 2005 | 04:10 AM
PandaXpress's Avatar
could be alot of things, bad injectors, spark plugs, gas and others
https://www.audiforums.com/m_163684/.../tm.htm#163784
Old Dec 18, 2005 | 12:10 PM
david9999's Avatar
How many miles?
When was your fuel filter changed?
Have you got access to a Vagcom so you can do some logging?
For Vag com location, check in the useful lists at the top of this forum. It contains the link to a vagcom locator toward the bottom.
Old Dec 18, 2005 | 12:21 PM
tontod's Avatar
105k miles. Not sure when the fuel filter was last changed. I dont have a vagcom, will check the list, thanks.
Old Dec 18, 2005 | 01:54 PM
tontod's Avatar
I'm going to autozone to get the car scanned and see what code(s) I get.
Old Dec 18, 2005 | 03:05 PM
sandman's Avatar
possibly coilpacks, common problem.
Old Dec 18, 2005 | 04:28 PM
tontod's Avatar
No codes from the scanning at autozone. I'm guessing the vag could still show a code without a CEL?
Old Dec 18, 2005 | 09:37 PM
tontod's Avatar
ORIGINAL: sandman
Hopefully thats all it is. How expensive are they?
Old Dec 19, 2005 | 12:24 AM
david9999's Avatar
Coil pack is about 24 dollars
cncbamf
May 9, 2017 05:39 PM
googlegot
Jun 10, 2012 06:25 PM
tketke
Nov 4, 2008 12:01 PM
limptimtim
Mar 16, 2007 11:21 PM
nitro_rider2001
Feb 27, 2007 07:39 PM
