Misfiring??
so i was coming back from the mtns this week and a spark plug popped out of my #1 cylinder. i already had the platinum plus 4 plugs and i put them in. now my car stutters and i believe its misfiring.. the CEL goes on and off and sometimes it blinks for a few seconds. i took off the plug boot and the rubber is broken on the #1 cylinder boot. would this affect anything? the rubber is the only thing broken
it says he has a 2.8 in hs sig[sm=WTFsgign.gif]
ORIGINAL: Bondga
Mmmmmm..... Platnum + turbo = bad. with turbo cars you shouldn't run platnum plugs because the tips tend to break off and chip the blades in the turbo. Iridium plugs are what are recominded
I had this happen to my probe, when it popped out the plug hole was threaded and gases were escaping around the plug after it was reinserted making it misfire. I had to use a drill and Helicoil to fix it.
