Mobil 1 vs. other synthetics
Old Dec 26, 2004 | 02:06 PM
  #21
1.8t20v's Avatar
Default RE: Mobil 1 vs. other synthetics
I had an oil sample done one time. I was at the 20k interval when I drained the oil and changed the filter. The data that came back basically said the oil was still good and I could have gone a little longer before changing.
Old Dec 27, 2004 | 11:01 PM
  #22
John_E's Avatar
ORIGINAL: CRAZYHAWK
Audi recommended specific synthetic oils including Mobil 1 0W-40. This is to prevent sludge.
Yes, 0W-40 "[pampered] European car formula" is the ONLY weight of Mobil 1 which meets VW 502. I would avoid Mobil 1 5W-30, because its 100C viscosity of 10 cSt is barely above the 5W-20 category, and hot-running VAG engines evidently generally need slightly thicker oil than those of some other manufacturers.
Old Dec 28, 2004 | 02:22 AM
  #23
zachd's Avatar
Thats the biggest thing is that the oil you are getting meets your manufacturers specs because even if it is the right weight it may not meet the specs required by your manufacturer.
xjmllc
Jul 17, 2014 08:25 AM
randy777
B7 Models
May 12, 2014 09:07 PM
hxgaser
Jun 19, 2011 03:30 AM
PurpleNerple
Mar 1, 2011 09:41 AM
ldtikk
Dec 8, 2008 06:45 PM
