moonroof/sunroof
Old Apr 10, 2013 | 12:41 AM
Bricksack's Avatar
Default moonroof/sunroof
Hey guys new to the site and the audi a4 ha. Just bought today has some minor issues.
THe moonroof works. But it tilts and clicks loudly when I moves it opens but not all thr way and also clicks loudly from the front of the glass. Once I do either I have to play with the switch to get it to close correctly. Anyone have a clue what it could be. Seems like motor is fine. The shade is jammed back wont come more than half way closed like its off track and stuck.
Old Apr 10, 2013 | 10:08 PM
ImTheDevil's Avatar
Sounds like broken guides on the tracks. Mine also clicks and I haven't removed it yet to fix it, but I've read of people having issues like this.
Old Apr 16, 2013 | 05:01 PM
MKE_Audi's Avatar
Similar problem here. Found that the wires were stripped and the teeth on the motor were also. I would suggest not opening until you get it fixed as mine had stuck open at one time and I was stuck only driving in good weather until I got it closed all the way. Using the manual override tool to turn the motor doesn't work either since the lines are stripped.
Mine still isn't fixed either as it hasn't been a priority but hopefully this summer I'll get to it. The fix is replacing the whole sunroof assembly so far as I've been able to find.
Old Apr 16, 2013 | 06:59 PM
sincityaudi's Avatar
There are plastic guides that are built onto the sunroof to keep the springs in the frame correctly positioned during opening and closing. You can buy these guides seperatley but they are easiest to install with the sunroof out of the vehicle. There are also block tabs that bring the sunroof back forward when the sunroof opens back all the way and then goes back forward they pull the sunshade forward a few inches. These were at one point available seperately but I think Audi changed that and now require the whole sunroof frame. Not cheap and the headliner, A-pillar, B-pillar and C-pillars have to be removed to do the job. I would advise paying an actual Audi dealership to do the job if you want it fixed because independent shops typically screw up something.. There are always exceptions and you may know of a good shop.
Old Nov 23, 2020 | 08:21 AM
Alex B's Avatar
Hello
I have the same issue on my Audi A4 Avant 2010.
When I hit the open switch, the sunshade does not open anymore and I can only hear some slight click.
Anyone here that managed to get this issue fixed and can share some hints?
Thank you
Alex
ManillaRoad
Audi Q5
Apr 24, 2011 05:30 PM
Joe_Mateo808
Jan 22, 2010 03:06 AM
a4nate3.0
Feb 19, 2009 11:48 PM
a4nate3.0
Sep 28, 2008 12:58 PM
