mutha flippen oil change
Old Jun 18, 2005 | 04:36 PM
black991.8tq's Avatar
Default ***** flippen oil change
so i tried to change my oil yesterday, key word tried. .... my plug is rounded like no other and after two hours of trying to get it off it still wont come. so i drained the oil out of the turbo line and then startrd on the filter and of corse it is on tight as a 12 year olds **** and i didnt have a friggen oil wrench that would fit it. i was out of time and had to get goin so i just filled up the oil and called it quits . any ideas on how to get the plug out ?
Old Jun 18, 2005 | 05:08 PM
bhj0887's Avatar
Default RE: ***** flippen oil change
if it's stripped you can go to sears and get a "stripped bolt remover".
Get the right oil filter wrench. If you puncture the filter it will come off a lot easier.
Old Jun 18, 2005 | 06:43 PM
apg96's Avatar
get the wrench form sears he was talking about and make sure u have a new drain plug before u pull the other one off
Old Jun 18, 2005 | 08:11 PM
Karl's Avatar
when replacing the drain plug dont forget the copper washer.. that is a key reason that a lot of drain plugs get stuck
Old Jun 18, 2005 | 08:33 PM
Cameron's Avatar
If the filter is really tight, puncturing may not be the best idea, even though it works really well. But if by some chance you can't get the filter off after you've poked a hole in it with a screwdriver for more torque, then he's not only going to have a stripped drain plug, but a ruined oil filter!
Old Jun 18, 2005 | 08:35 PM
Karl's Avatar
more motivation to take it off. what do you think he is going to do.. drive the next 100k miles with the same filter? Bottom line is that thing needs to come off.
Karl's Avatar
also make sure you wipe a small amount of oil onto the new oil filter.. I am sure you knew that but just to make sure
Old Jun 18, 2005 | 10:35 PM
headshok2002's Avatar
Those special sockets that take off the stripped bolts work UNBELIEVABLY well. I had a lug nut that was stripped from the previous owner, and I think they stripped it while tightening it to what I figure was about a million lbs of torque Anyhow, it was retarted... I had hammered on a socket that was too small, and applied an unreal amount of torque to that, before the socket split in half. The craftsman things handled even more torque, and got the bastard loose.
As for your oil filter... those rubber band typa wrenches work really well, or yes, the screwdriver... but the screwdriver will make a damned mess, what with the oil everywhere... I did 3 oil changes this past weekend... my a4, my camaro, and my girlfriends civic. All went smoothly, cept the stupid z28 is leaking oil from the intake gasket... GAY -- SURE HAPPY I WASNT USING ROYAL PURPLE @ 10 BUCKS A LITRE. ... no wait, I was... and its leaking like a bizatch.
Old Jun 18, 2005 | 10:59 PM
Karl's Avatar
Ouch sorry to hear that....
Old Jun 18, 2005 | 11:27 PM
dafrazi's Avatar
Use a pipe wrench on the drain plug. Work great but destroys the plug.
