My Car Is Killing Me
If the master is out I would bench bleed it and then run a pressure test. I don't know what Audi's make for pressure but a good master cyl will make/hold 1000psi in the lines. I know cuz when I fabricated a corvette MS with 15' discs all around on my rock crawler we were over that mark
dont worry man this is gunna fix her and you will be reunited, but you better quit talkin bad about her or other things are gunna start goin bad just to spite you
ORIGINAL: PandaXpress
i hope it is cause thats wat is being replaced
i feel so helpless with out a car
is there a pedal return spring on A4's? or is it just hydraulic pressure that holds the pedal where it should be?
the only things left that you haven't checked are the proportioning valve and the abs pump...
yea finally problem fixed, im so happy
i dont know what my uncle did casue i was in a rush when i picked up my car but finally my brake problems are over
but story of my life when one thing gets fixed another breaks
my fog light blew, i think casue i ran over a huge puddle and water got it[&o][&o]
at least its an easy fix
one think taken off the list and anther added on[&o]
glad you got your brakes fixed... id rather have brakes than fog lights so i think your still ahead in the game
