my codes
Old Sep 30, 2006 | 08:35 PM
duffman's Avatar
Default my codes
p1136 fuel trim too rich at idle (bank1)
p0422 catalyst system efficiency below threshold (bank1)
what do these mean?
thanks
Old Oct 1, 2006 | 02:48 AM
duffman's Avatar
Default RE: my codes
99 1.8t by the way
Old Oct 2, 2006 | 04:11 AM
socals4driver's Avatar
sounds like a possible boost leak...you should make the 10 tester, i am unfamiliar with the 1.8 engine and what the possible leak issues are, do you have a boost gauge?
Old Oct 2, 2006 | 05:25 AM
duffman's Avatar
my inlet hose into the airbox was barely on, and it wasnt sinched down. also the air compartment next to the air box (drawn in from outside) was filled with crap. i changed the air filter and tightened everything up. i wonder if that had anything to do with the car running rich.
Old Oct 2, 2006 | 01:30 PM
CRAZYHAWK's Avatar
Clear the codes, and see if they return.
Old Oct 2, 2006 | 04:23 PM
duffman's Avatar
so far so good, i cleared them 2 days ago, and they have yet to return. we'll see.
Old Oct 2, 2006 | 04:32 PM
CRAZYHAWK's Avatar
If they don't return you're good.
Old Oct 3, 2006 | 06:18 PM
duffman's Avatar
what is the 10 tester?
Old Oct 5, 2006 | 10:19 PM
duffman's Avatar
i was clear for 200 miles, my light came on today...ill find out what codes they are this time and post them.
Old Oct 5, 2006 | 11:44 PM
duffman's Avatar
only p1136 this time...what could be causing it?
