my codes
P1136 17544 Long Term Fuel Trim Add. Fuel Bank 1 System too Lean
If this is correct, look for vacuum leaks.
Start with the L shaped formed hose on the back and side of the intake
manifold. Then check the Y shaped hose in back of the intake manifold.
Good luck
Good luck
holy cow there are a ton of hoses...
the hose coming from the intercooler to th intake seems to be fine, as do the little ones going into the back.
anything else i should check?
is the maf right on top of he air filter housing?
P1136
17544
Long Term Fuel Trim Add. Fuel, Bank1
System too Lean 2)
- Check intake air system for leaks ("false air") Page 24-97 Check vacuum hoses for leaks. listen for hissing. Yes, take the engine cover off so you can see the hoses. The thin vacuum hoses crack easily.
- Check Mass Air Flow (MAF) sensor -G70- Page 24-57
- Check fuel pressure regulator and residual fuel pressure Page 24-93
- Check fuel injectors Page 24-87
- Output Diagnostic Test Mode (DTM) Page 01-42
Most likely the first or second. Most likely vacuum leak from a cracked vacuum hose. Second most likely is is the MAF.
17544
System too Lean 2)
