MY CRUISE CONTROL WON'T WORK!!??
Old Aug 24, 2007 | 02:16 PM
mind5050's Avatar
Default MY CRUISE CONTROL WON'T WORK!!??
Hey guys,
I have a '99 2.8Q 5 spd..
the cruise control will not come on...
I try to set it but the light never comes on and it doesnt work..
I tried to locate the fuse to see if it was burnt but the fuse diagram in my owners manual only showed the fuse placement for automatics...
anyone know which fuse it is for 5spds?? or have any other tips ??
thanks for any help
-nick
Old Aug 24, 2007 | 03:18 PM
akielb's Avatar
Default RE: MY CRUISE CONTROL WON'T WORK!!??
search and ye shall find the light(<cruise light that is) - its a common problem, could be a few different things - use the search button and you'll find a lot of info
Old Aug 24, 2007 | 04:56 PM
qUaTtRoA4's Avatar
did ur car used to have a light? if not...I had a similar problem when I first bought the car....I have no light on the dash that indicates that my cruise control is on. Besides that, I had to jiggle with mine for the longest time to finally figure out how to engage and contral the speed. before looking for a fuse, run it up to the speed limit on the hwy. and then flip the cruise control off, then on then set...if it works you will feel it, and there will be no light
Old Aug 24, 2007 | 06:55 PM
mind5050's Avatar
I know how to work the cruise control.... I definitely turn it on and set it correctly but it just does not work
Old Aug 24, 2007 | 07:45 PM
99A4NOW's Avatar
If you want to check the fuse but dont' know which one it is- check them all. Most cruise control problems are either the switch or the control module. Mine was the control module, but rather than buy one on ebay for $60 I broke out the soldering iron and soldered half of the circuit board. It's been working great since, but I do notice some problems with the switch every once and a while. I might have to cycle it off and on twice before it takes. There are some good threads on here somewhere and I think there is a tech article on one of the Audi Forums (maybe AudiWorld?)
Old Aug 24, 2007 | 08:59 PM
A4 Effort's Avatar
The '99s don't have a CC light - mine doesn't.
Your problem could be a couple things. Either a bad or dirty switch, or possiblya vacuum leak somewhere that's preventing it from engaging. There are a few write-ups on how to clean or replace the switch on here, try searching for it.
cstew69
Dec 22, 2008 10:05 PM
gen2roller
Sep 4, 2008 06:36 PM
arturttq
Dec 28, 2007 11:44 PM
A4 the Quattro
Mar 16, 2006 07:07 PM
QUICKA6
Jul 16, 2005 09:33 PM
