need answer quick! the rain is on the way!
that recirculation hose will not cause a leak bc alls it is doin is directin the air to the intake for the maf. if its such a small hole u might loose a little air that the maf wont read but not enough to make a diff. granted its good to replace items like that. if u cant find that hose i have one i dont use just pm me
Well that depends on what side of the DV it's on tho.... because if it's on the intake side (not the return) it would be under 15-17psi like he said. If that were the case it leaks like mad under psi and shorts the motor for air after the MAF.
well its on the passenger side of the turbo....the DV connects into it.
blackvision is this the hose you have? if it is then i'm down for buying it. do you do paypal?
