Need help with CEL and tranny code on B6
Old Nov 11, 2007 | 08:45 AM
B6er's Avatar
Default Need help with CEL and tranny code on B6
Here's what I got. It's the wifes car, totally stock 2004 a4 1.8TQ. 44K miles Solid CEL so safe to drive. She explained to me there have been no running problems or wierd behavior. I've only seen rndom misfires on ones with ICMs. The transmission one is puzzling. Any advice? I feel so stupid about this. I would have probably done everything if it weremy passat, but the A4I am hesitant because it's still under waranty. I'm just looking to see if I can diagnose better thant the stupid dealer.
VAG-COM Version: Release 409.1-S
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01: Engine
Controller: 8E0 909 518 AK
Component: 1.8L R4/5VT G 0004
Coding: 0016751
Shop #: WSC 63351
3 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - Implausible Signal - Intermittent
16686 - Shareware Version. To Decode all DTCs
P0302 - 008 - Please Register/Activate - Intermittent
16687 - Shareware Version. To Decode all DTCs
P0303 - 008 - Please Register/Activate - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans
Controller: 8E0 927 156 S
Component: AG5 01V 1.8l5VT USA 1212
Coding: 0001002
Shop #: WSC 63351
1 Fault Found:
17095 - Transmission Fluid Temp Sensor (G93): Implausible Signal
P0711 - 003 - Mechanical Failure - Intermittent
TIA!!
Old Nov 11, 2007 | 08:52 AM
techbod's Avatar
Default RE: Need help with CEL and tranny code on B6
VAG Release 409.1-S ? im surprised it even tried to find the fault because its a 2004 car and you need newer up to date VAG software because its CAN bus
Old Nov 11, 2007 | 08:56 AM
techbod's Avatar
704 is what you need
http://www.ross-tech.com/vag-com/download/
Old Nov 11, 2007 | 08:59 AM
B6er's Avatar
It's not a can bus. http://www.ross-tech.com/vag-com/car...ions/a4s4.html I don't need another version, this works fine. Thanks for the help.
Also, the driver side rear outside door handle fell off somehwere. Anybody got a part number for that? I don't think the dealer would cover because they could just say someone stole it.
Old Nov 11, 2007 | 09:09 AM
techbod's Avatar
of course itsCAN bus integrated and even more so with the 2004 ( full CAN bus comes in 2008 ) but CAN has been around longer than you think
edit: I know nothing lol
Old Nov 11, 2007 | 09:11 AM
B6er's Avatar
Whatever, I pulled codes, that's allI need. I was just asking for help, not someone to nit pick my vagcom version.
Old Nov 11, 2007 | 09:16 AM
techbod's Avatar
its not a case of nit pick but I hear what your saying and a simple answer is ( different tools give different answers ) so your diagnostic could be wrong ( P1296 for instance = short in coolant temp sensor but my other diagnostic says its 02 sensor bank 2 ) im just stating the facts
Old Nov 11, 2007 | 09:32 AM
B6er's Avatar
The simple fact that it will pull a code means it works. The modules I need to access work fine on the "Key" interface. Ross-tech says that too.
Old Nov 11, 2007 | 09:35 AM
techbod's Avatar
im going to go with you on this one because its a tranny problem and not my area
17095 - P0711 so its the same thing according to my data but 17095 doesn't exist in my data ( it stops at 17092 ) at a guess it seems the sensor is at fault
Old Nov 11, 2007 | 09:42 AM
techbod's Avatar
Removing and installing oil pan, ATF screen and valve body[/align]Replacing gearbox oil temperature sender (ATF) -G93[/align]
Note:
The gear oil temperature sender -G93 is integrated in the gearbox wiring harness.
Removing
‒Remove wiring harness in gearbox Installing[/ul]
Install in reverse order. The following steps must also be performed.
‒Replace the wiring harness with a new one. [/ul]
