Need help, local mechanic is useless.
Old Aug 1, 2006 | 06:22 PM
acetrebo's Avatar
Default RE: Need help, local mechanic is useless.
I thought it could be the other way around, ie the misfire was causing the other code, but thats why I like this forum, you learn something new everyday.
Like you said, cant hurt to try switching the coil packs, if no air leak is evident.
Old Aug 1, 2006 | 06:35 PM
techbod's Avatar
P0171 rules that out because it states air leak rather than misfire issue but I suppose it could easily work both ways.
Old Aug 1, 2006 | 07:28 PM
Havors's Avatar
some great info guys thanks.
Im gonna get the mechanic to check for a vaccum leak as its sounds like it could be whats causing the missfiring and the high revs when idle.
I'll let you know how i get on.
Old Aug 3, 2006 | 10:35 AM
Havors's Avatar
right! The mechanic says there are about 3 pipes that are almost perished. Are these to do with the vaccum leak you guys mentioned?
Could any of you point me in the direction of a cheap audi parts dealer as I dont want to get ripped off getting it done at the Audi dealers.
Old Aug 3, 2006 | 12:53 PM
onepoint8tee's Avatar
If its just vaccum lines, its cheap to buy, even at the dealer. Did your mechanic actually show you the "pipes" that are about to "perish"?? We would have to know exactly what pipes or lines are going bad to verify anything or help you with prices and labor.
Old Aug 4, 2006 | 07:58 AM
Havors's Avatar
Not yet ive got to pop in and see him later, he said he would show me. Ill let you know.
Old Aug 4, 2006 | 06:12 PM
Havors's Avatar
OK he says that the "Crank case breather" needs replacing. He showed me it and its practically got a big hole in it.
He said the rest of the pipes have just began to soften. Do they not just do that when hot anyway?
Can anyone help on where to pick one of these up? Should I just pop down to audi dealers?
Old Aug 4, 2006 | 06:18 PM
  #18
techbod's Avatar
replace all those pipes because when they get hot they collapse with age and obscure ventilatilation for the engine
Old Aug 5, 2006 | 08:25 AM
  #19
Havors's Avatar
Well im gonna have to go to the Audi dealer for them. Unless anyone knows anywhere cheaper?
How much are the pipes anyway?
  #20
Havors's Avatar
