Need help with these codes please
ok the first set of codes are pulled off my 01 A4
1)Address 01: Engine
Part No: 4B0 906 018 CH
Component: 1.8L R4/5VT G 0001
Coding: 16201
Shop #: WSC 63351
1 Fault Found:
16826 - EVAP Emission Control Sys: Small Leak
P0442 - 35-00 - -
Readiness: 0000 0000
2)Address 03: ABS Brakes
Part No: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
No fault code found.
3)Address 08: Auto HVAC
Part No: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D58
Coding: 00040
Shop #: WSC 63351
4)Address 15: Airbags
Part No: 8D0 959 655 G
Component: Airbag Front+Kopf 1002
Coding: 00304
Shop #: WSC 63351
5)Address 17: Instruments
Part No: 8D0 920 932 K
Component: B5-KOMBIINSTR. VDO D12
Coding: 02344
Shop #: WSC 01518
6)Address 35: Centr. Locks
Part No: 8L0 862 257 N
Component: CV-Pump, Alarm, RC D16
Coding: 15945
Shop #: WSC 63351
2 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
7)Address 45: Inter. Monitor
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 63351
1 Fault Found:
01380 - Alarm triggered by Anti-Theft Sensor; Rear Left
35-00 - -
8)Address 55: Xenon Range
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 63351
End --------------------------------------------------------------------------------------------------
I have no idea whats happening so if someone could please explain i numbered them to make it a bit easier thanks
Please let me know if these are serious and what they are.
also if it gices me something like this is it anything cuase at the bottom it says there is no fault ? thanks
Coding: 00012
Shop #: WSC 63351
Coding: 16201
Shop #: WSC 63351
1 Fault Found:
P0442 - 35-00 - -
Coding: 00040
Shop #: WSC 63351
Coding: 00304
Shop #: WSC 63351
Coding: 02344
Shop #: WSC 01518
Coding: 15945
Shop #: WSC 63351
2 Faults Found:
35-00 - -
35-00 - -
Coding: 00101
Shop #: WSC 63351
1 Fault Found:
35-00 - -
Coding: 00012
Shop #: WSC 63351
Coding: 00012
Shop #: WSC 63351
when was the last time the codes were cleared? You really have no idea of knowing how old these codes are. Reset them and see if they come back. Or is there an actual problem you are debugging?
None of these are really a big deal. Just make sure your gas cap is tight.
01367 - Central Locking Pump Run Time Exceeded (Likely Leak) - This is probably not a leak. As long as all of your doors are locking properly you are fine. This type of code tends to appear occasionally. If this code comes back continuously, then you have a problem.
Clear the codes (if you haven't already), and see if they come back.
i had cleard teh codes in december and this is what came back. also my check engine light was on before i cleared these codes and now today (a day later ) the check engine codes came back. im gonna rescan it tonite and see whats there now
16826 - EVAP Emission Control Sys: Small Leak - This is causing your CEL.
Bentley manual says to check the EVAP canister purge regulator valve (N80). First check fuses 28, 32, and 34. Not exactly sure which one, but they all have to do with the fuel system. Next, the N80 valve is located over the airbox (see pic). Pull off the connector and check the resistance with a multimeter. It should read within 22-30 ohms. Make sure the ignition is off for this. Hopefully this helps.
[IMG]local://upfiles/18457/1FB620804B034A1EB6FE77F746848F4B.jpg[/IMG]
