Need Help w/ Misfire - 2.8L A4 (B5)
Old Aug 11, 2007 | 09:40 PM
brightside06's Avatar
Default Need Help w/ Misfire - 2.8L A4 (B5)
Recently my 98 A4 Quattro 2.8L (90k) has been idleing rough around 500 rpm. Took it to 2 shops and everything seemed to be fine to them. Today when I took it out the Check Engine Light turned on and was blinking which reads a misfire. I'm hooking it up tomorrow to see what codes they throw at me, but first of I checked all the plugs and wires and all seemed firing correctly. But what confused me was the fact that when i took out the spark plugs the tip was covered in oil on every plug. Typically that's not good at all. I also took off the pvc valve to see if it was blowing smoke, and indeed it was. What could this problem be? I'm clueless and starting to get pissed off with the car, but I love my Audi so I need it fixed. Anyone have any advice?
-Chris
Old Aug 12, 2007 | 01:32 AM
CRAZYHAWK's Avatar
Default RE: Need Help w/ Misfire - 2.8L A4 (B5)
Get new spark plugs and change the oil.
Use on of the following:
Castrol, Castrol Syntec 5W-40
Chevron, Chevron Supreme Synthetic 5W-40
Elf, Elf Excellium LDX 5W-40
Kendall, Kendall GT-1 Full Synthetic Motor Oil 5W-40
Mobil, Mobil 1 0W-40
Pennzoil-Quaker State, Pennzoil Synthetic European Formula 5W-40
Pennzoil-Quaker State, Pennzoil Synthetic European Formula Ultra 5W-30
Pennzoil-Quaker State, Quaker State Full Synthetic European Formula 5W-40
Pennzoil Quaker State, Quaker State Full Synthetic European Formula Ultra 5W-30
Seventysix Lubricants, 76 Pure Synthetic Motor Oil 5W-40
Texaco, Havoline Synthetic 5W-40
Total, Total Quartz 9000 5W-40
Valvoline, Valvoline Synpower 5W-30
Valvoline, Valvoline synpower 5W-30
Old Aug 17, 2007 | 07:39 PM
The check engine light showed the Idle Air Conrol Valve is bad. Where is this located on '98 2.8l, code AHA? I've looked everywhere online and cannot find anything. Any ideas???
Russ Heinrichs
Aug 18, 2021 12:39 PM
dorkfish
May 6, 2013 09:58 AM
slow_key
Sep 23, 2010 08:25 AM
themahr
Mar 31, 2009 03:50 PM
