Need Mad Help
Old Oct 17, 2006 | 09:49 PM
  #21
The Bishop's Avatar
Default RE: Need Mad Help
Yes, the computer will figure it out. but now it just thinks the MAF is broken.
Old Oct 17, 2006 | 09:58 PM
  #22
techbod's Avatar
[IMG]local://upfiles/12092/66D9533D399B4E589D3F75F1BE569E48.jpg[/IMG]
Old Oct 17, 2006 | 10:03 PM
  #23
techbod's Avatar
the computer can only decipher small movements recorded to the ECU, cant fit a K04 without chipping/flashing can we
Old Oct 17, 2006 | 10:15 PM
  #24
Jeff's Avatar
Zombie Defense Force
did you use the stock maf housing or did you change it to a larger one? if you went to a larger dia. maf housing then thats your problem
Old Oct 17, 2006 | 10:23 PM
  #25
xAUDIx's Avatar
ORIGINAL: Jeff
Stock. ill go down there and plug back in the battery and check to see if everything is all in place then ill get back to you guys.
Thanks for all the helkp so far
Old Oct 17, 2006 | 10:24 PM
  #26
xAUDIx's Avatar
ORIGINAL: Jeff
Old Oct 17, 2006 | 11:14 PM
  #27
The Bishop's Avatar
No it can't adjust for drastically different components like a ko4, but it can readjust the stock sensors.
Old Oct 18, 2006 | 12:05 AM
  #28
Bip's Avatar
Bip
In my opinion my stock airbox was the same if not better than my cold air intake. I have a CAI sitting around becuase i use my stock one again, i trust it more. I think its just the little noise the CAI makes that seems faster or whatever you want to call it. just my 2 cents
Old Oct 18, 2006 | 12:33 AM
  #29
xAUDIx's Avatar
ORIGINAL: Jeff
is it possible that you put the maf on backwards???
[sm=sigh.gif][sm=youreright.gif]
Old Oct 18, 2006 | 12:41 AM
  #30
Jeff's Avatar
so was i right???
ORIGINAL: xAUDIx
ORIGINAL: Jeff
