need some diagnostic advise (UPDATED)
Old Jul 4, 2005 | 12:21 AM
  #21
audiboy1618's Avatar
Default RE: need some diagnostic advise
Sounds like a dv prob, the 71on didnt to **** for my ko4 setup, i even bought a new one. Then, threw in a baily and worked well. From my expeirence, its a boost leak. When ur running this much psi on a ko4, hose's are going to fly, heck, 2 weeks ago i blew off a hose coming of my manifold.
btw- when i say blew, i mean blew. not just a crack and boost seeping out. This b!!ch flew off like a fire hose with nobody hangin on to it.
Old Jul 4, 2005 | 01:16 AM
  #22
lidonnit's Avatar
I'm leaning toward dump valve too now. I would still check your fuel intake though. It may not be getting enough.
Old Jul 4, 2005 | 01:22 AM
  #23
Fuel intake has nothing to do with it.
Old Jul 4, 2005 | 01:29 AM
  #24
black b5's Avatar
i removed,inspected and tested both of my 710n valves
they both are in great shape, about 10hg vac starts to open them
i questioned if it was too much cfm for the spring inside the valve to handle and it might push the valve open?
inspected both seals, no tears at all. since pressure comes in the side of the valve i would see a rip in the diaphram i think?
it would be strange if the one i bought 5 months ago for my chip worked for about a week and a half with the k04 and a new one doesnt work at all?
[sm=headbang.gif]
strange thing was it run just a good on the k03 x-chip software as it did for 3 days on the k04 program
Old Jul 4, 2005 | 01:33 AM
  #25
black b5's Avatar
when i pressure tested i pulled the pcv valve out of the intake hose and plugged that hole
stuck my rig in the intake hose at the maf connection and pumped up to 20psi
my intake hose swelled like a ballon but no leaks.
Old Jul 4, 2005 | 01:42 AM
  #26
lidonnit's Avatar
Thats a good way to test the hoses definitely. :-)
The reason I said fuel, was we had that problem with my old car, almost identical actually (not an audi though). Thats why I bought it up.
Old Jul 4, 2005 | 01:57 AM
  #27
black b5's Avatar
i vag'ed it earlier today with the trial version you download from ross-tech
i had 3 codes stored, no cel
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17952 - Angle Sensor 1 for Throttle Actuator (G187): Signal too Large
P1544 - 35-10 - - - Intermittent
i cleared all 3 and drove the vehicle for 20 min. pulled in the garage and rechecked.
no codes present but problem still exsist[&o]
Old Jul 4, 2005 | 02:00 AM
  #28
Uuummm, its not suppose to swell i dont think, is there any chance u have something"clogging" in ur system, and your not getting all ur airflow. Give tom a pm about this, he will have a good idea.
  #29
lidonnit's Avatar
Wow... your car must be pretty quick... Anyway, if it were me, I'd take it to the docors to have a physical.
Old Jul 4, 2005 | 02:02 AM
  #30
black b5's Avatar
ORIGINAL: audiboy1618
the intake hose from the air box the the turbo inlet isnt meant for charge pressure but it tested it anyway
