need some help with vag connection
Old Sep 14, 2005 | 01:48 AM
black b5's Avatar
Default need some help with vag connection
here is the scoop. i just bought a dell laptop 600M so i can use vag-com and lemmiwinks.
i have a generic interface cable that works with my home pc and version 311.2 but i get a interface not found
error message when trying to run setup test on version 311.2 on my laptop.
i have read some info stating that i need to shut off hotsync to release the com 1 serial port? i have no ieda what that means.
any computer guys here that can help me out would be great.
Old Sep 14, 2005 | 02:27 AM
onepoint8tee's Avatar
Default RE: need some help with vag connection
The only problem I had at first, with my laptop, was that the computer couldnt coummunicate with the com port. I have a serial cable from the vag to a usb adapter that goes into my computer. I had to go into control panel/system/hardware/device manager, and go into the properties to make the "unkown device" on com 2, (or whatever com #'s 1-4 is available.) Restart the software and try it. That may help you out, good luck.
Old Sep 14, 2005 | 02:34 AM
Sorry that didnt make much sense. Do this:
click "system"
click "hardware"
click "device manager"
click the little plus sign for "Ports"
click the one that has a yellow question mark
click the "port settings" tab
Select a port number between 1 and 4, preferably 1 or 2. Dont mess with any of the other settings. Restart your software and it should recognize it.
MGiroux88
Sep 3, 2013 08:51 PM
kevace1
Feb 8, 2010 08:45 AM
dnik
Feb 4, 2008 02:58 AM
rossifumi
Jan 8, 2008 03:04 PM
cary12
Mar 25, 2006 02:46 PM
