need some info on chips...
Old Dec 17, 2004 | 04:10 PM
audiboy1618's Avatar
Default RE: need some info on chips...
You can drive to a dealer and they will put it in 30min.
Old Dec 17, 2004 | 04:34 PM
David_K's Avatar
ORIGINAL: alejandrorodrigu
ok, computers and systems are my business, if you connect your ecu to a linux computer you can see the ecu like a memory stick atached to your computer (the computer program is an .txt file created in unix based systems (siemens)), then you can copy all the info to your hard disk... then you can use the usb port with a windows pc to put the apr software in the backuped ecu, off course the dealer can see if your computer is chipped, they plug a turbo psi tester in the car and they will see an out of range psi in the turbo, that is the way... in mexico there is a lot of warranty refuse in this case... they use this simple way to check if your ecu is not with the original parameters.
thats true i have heard of dealers tapping int the boost readings.
Old Dec 19, 2004 | 01:21 AM
alejandrorodrigu's Avatar
revo and apr, just go directly to the dealer, there exist a test mode, then you can probe it before you pay ! and you dont have to send the ecu, i heard that the best ecu program is the oettinger, but you have to send the ecu to germany !
Old Dec 19, 2004 | 03:22 AM
John1.8T's Avatar
if i do this i'll probably end up buying another ECU and chip it. That way i can keep the stock one and swap them when it goes to the dealer. The APR chip is selling for 450 right now on the Stage I chip. Not a bad deal to gain 40 hp.
Old Dec 20, 2004 | 01:19 AM
maibe you can buy the sub conexion to the ecu, and use the apr programing software (free download)
brascal44
Jul 4, 2008 08:18 PM
jjuzwik
Nov 16, 2007 06:37 PM
umairejaz
Apr 7, 2005 12:46 AM
kourosH
Mar 8, 2005 01:30 AM
jmmd420
Aug 12, 2004 09:06 PM
