Needing Advice on Audio speakers 1996 A4
Old Aug 1, 2007 | 01:12 AM
Deply's Avatar
Default Needing Advice on Audio speakers 1996 A4
When I first bought my 1996 Audi A4, the right driver side door speaker crackled, since then I've taken out the crackling speaker and have been in search for a replacement. I called a local Audi dealership to see if they could order a non-bose driver side subwoofer/speaker for me. The speaker was going to cost $140 to replace through Audi. Does anyone know of any after market speakers that would fit a 1996 Audi A4 specifications or does anyone know where to a get a cheap speaker online or otherwise??
Old Aug 1, 2007 | 01:47 AM
MrFlippant's Avatar
Default RE: Needing Advice on Audio speakers 1996 A4
I'd check out a scrap yard, or maybe find a parts car in the buy/sell section of this forum or on eBay or something. $140 sucks hard... for that, you might as well just upgrade to some aftermarket speakers, which will require custom fitting since no one makes component speakers as small as the factory ones, and if you get coax you can find the right size but you'll need a bracket to fit the bolt pattern. Consult your local car stereo store on that.
Old Aug 1, 2007 | 02:18 AM
kraylon's Avatar
you can get adapters to fit 5.25 aftermarket speakers in the doors or someone on here used dynamat to hold in the speakers but i don't rember who try a search under dynamat on the site
Old Aug 1, 2007 | 06:30 AM
A4 Effort's Avatar
...no one makes component speakers as small as the factory ones.
There are a couple companies that make 4" component sets. I had a set of Polk EX2540 4" components in mine a while back.
You really don't need component speakers. Just get yourself a set of either 4" or 5.25" coaxials and you'll be fine.
Old Aug 1, 2007 | 10:28 AM
grim2.8's Avatar
try Bluapunkt or MB/Quart i think both of them make speakers to fit B5 A4's
Old Aug 1, 2007 | 04:37 PM
spamilton1's Avatar
I just put 4 inch polks in mine last weekend, you have to make a bracket (not hard), or use dynomat (also looked easy but i'm cheap and had 1/4 inch ply lying around). I somehow got misslead into believing that i had back speakers (which i don't) and bought an extra pair of 4's. I was going to return them but will give you a crack at them if you want.
Old Aug 1, 2007 | 05:03 PM
spamilton1's Avatar
oh an shokan parts wants $70 plus shipping each, which is more than almost any aftermarket one. plus paper cones get wet, it's science
Old Aug 1, 2007 | 11:47 PM
sdsteez's Avatar
ORIGINAL: spamilton1
wait, you dont have back speakers?
anyways, theres tons of companies that make 4" speakers. get 4" up front and 6.5" in the back and dynamat works great i used it.
MrsHoffer
Apr 21, 2015 11:52 AM
SuperDave417
Aug 1, 2013 10:40 AM
ggarland
Mar 27, 2011 12:58 PM
Schaefer50
Apr 19, 2010 04:54 PM
lazyjayz
Jun 13, 2007 03:07 AM
