New Car(to me) need help!
Old Dec 17, 2011 | 10:26 AM
turbo kraut's Avatar
Tech Guru
There was a recall on the pack go to audi dealer and swap them
Old Dec 17, 2011 | 10:36 AM
NewToTurbo's Avatar
I'll do that today and tell you how it runs, thanks for the updates I will keep you informed.
Old Dec 18, 2011 | 07:58 AM
Jchockey100's Avatar
Try coil pack/spark plugs, if not that MAF and could possibly be one of your valves not opening when it should be.
Old Dec 18, 2011 | 09:09 AM
NewToTurbo's Avatar
I replaced the coil packs, seems to be doing a lot better, did the muffled noise once or twice in 30 minutes of driving maybe for 2 seconds, before it was for like 20 or 30 so maybe it needed the new packs and just needed to clean the crap out? I don't know. The car got in a rear accident before I had it and I think the ECU got hit stupid, the next thing I'm going to replace is that and the gas tank/fuel pump. What is the MAF? Never heard of that. The power control module, the one mounted in the rear right corner needs to be replaced too.
Old Dec 18, 2011 | 11:03 AM
Tech Guru
mass air flow sensor, sits in the air box
might also be the ignition control module(known issues) starting to go bad, sits on the heat sync on top of the airbox..... did you change plugs while you had the coils out?
i'd definatly change those if not..... ecu is up front in engine bay no way the accident hurt it
doubt the accident hurt the pump either, 174 k it might be time for a new one, but that is not a rush thing imho
don't buy electronics from autozone
