New engine cranks but wont start
Old Jun 17, 2007 | 07:38 AM
  #21
david9999's Avatar
Default RE: New engine cranks but wont start
Check the connections at the ECU. I believe that there is also a fuse inside the ECU box.
Old Jun 17, 2007 | 12:18 PM
  #22
wemmington's Avatar
Connections are good. I opend the ecu and no fuse.
Thanks
Old Jun 18, 2007 | 01:09 AM
  #23
wemmington's Avatar
Even if the ecu is not working properly shouldnt I be able to communicate with some other device in the car? Its a manual tranny so im assuming there is no TCU but is there somthing else I can try to scan? Im tring to figure out if the ecu is bad or scan tool is not working or maybe a wiring issue. Is there some way to test the ecu? I want to bring this car back to life so bad it hurts. Please help
Old Jun 18, 2007 | 02:56 AM
  #24
techbod's Avatar
pin data for the ECU 2 of 9
[IMG]local://upfiles/12092/D6FCC24CF10A4CA0B1202E58523AA6C6.jpg[/IMG]
[IMG]local://upfiles/12092/709C1B17FF6D490E8A6F3C2C71DCF40B.jpg[/IMG]
Old Jun 18, 2007 | 02:57 AM
  #25
techbod's Avatar
4 OF 9
[IMG]local://upfiles/12092/715D0CF53ABA49F0B1DCF868C74174A1.jpg[/IMG]
[IMG]local://upfiles/12092/9B0F6585B92140BD9C7CDE7ED00AD345.jpg[/IMG]
Old Jun 18, 2007 | 02:58 AM
  #26
techbod's Avatar
6 of 9
[IMG]local://upfiles/12092/589D2A13C3A240C783AF115CE52CF2A3.jpg[/IMG]
[IMG]local://upfiles/12092/9C0BC3D140C6484DA9D9C7CCA6149A42.jpg[/IMG]
Old Jun 18, 2007 | 02:59 AM
  #27
techbod's Avatar
9 of 9 a lot of information there
[IMG]local://upfiles/12092/68BF96EB190A40F78335E86AC796A78E.jpg[/IMG]
Old Jun 18, 2007 | 03:04 AM
  #28
techbod's Avatar
just one more to help you decide why it wont start
[IMG]local://upfiles/12092/1DE669B2B7AB48C8987DDE86F198488A.jpg[/IMG]
Old Jun 18, 2007 | 11:27 AM
  #29
kpatz's Avatar
Did you say that the fuel pump runs (and fuel comes out of the rail when you had it open) for a couple seconds when you turn the key on? This is normal, and I expect the ECU is working if this is happening (the ECU runs the pump for a couple seconds to pressurize the system). When you crank the engine, does the pump run/fuel come out then?
I'd recheck the ECU connections, maybe something didn't get hooked up correctly during the engine install.
Old Jun 18, 2007 | 11:56 AM
  #30
wemmington's Avatar
ORIGINAL: kpatz
Thanks for all the replies
I'm not sure if fuel is coming to the rail when I crank but it does shoot a little when I put they key in the acc position and I know that the injectors are not firing when it cranks. I think your right tho, I dont think something got hooked up or something was hooked up wrong during install. Two things I am certain of, injectors wont fire and I cant scan ecu and my guess is they share the same problem. Is there a ground wire for the engine that maybe didnt get hooked up? If I could just scan the ecu I could get an idea where to start.
stemiched89
Mar 2, 2014 12:43 PM
millsi
Oct 9, 2013 09:18 PM
william ashton
Jun 17, 2012 11:51 PM
wieganout
Aug 20, 2011 11:41 PM
