New guy with some trouble
Old Nov 26, 2010 | 07:41 PM
willsbma's Avatar
Default New guy with some trouble
Already searched multiple times and still cannot figure out this cooling system problem. Long story short...ran something over, knocked out the coolant temp sensor which leaked coolant everywhere. Replaced sensor & o-ring, filled with coolant (held res up and filled with bleed screw open)
Engine does not overheat, but I have no heat in the cabin. Water pump is new, radiator is new, t-stat is functioning (hot hose test)
Bled HC from little hole on top hose (very messy) for 30-40 min. Lots of air/steam but no solid stream of coolant.
Removed lower hose from heater core and it got hot (like coolant was circulating) Put hose back on and no flow. Where does the lower heater hose connect? Appreciate any and all help. TIA
ETA: Heat worked fine before the sensor got knocked out
Old Nov 26, 2010 | 10:33 PM
willsbma's Avatar
bump for any ideas?
mcj2400
Feb 26, 2013 03:59 PM
ang7610
Jun 15, 2008 10:58 PM
msimsi
Jan 27, 2008 08:07 PM
audi9605
Dec 29, 2006 02:54 PM
abdi21
Aug 16, 2006 09:00 AM
