New w/question
Old Feb 7, 2006 | 11:35 AM
blever's Avatar
Default New w/question
I just bought a 98 A4 2.8 FWD with the tiptronic trans. The transmission has a slight pan leak. WHen I replace the gasket I was wondering what kind of fluid you would recommend. Also I know the fill is through the bottom. What is the best way to add fluid?. I'm also replacing the water pump/timing belt. What coolant do you recommend?
Old Feb 7, 2006 | 11:41 AM
Jestnomen's Avatar
6th Gear
Default RE: New w/question
I would opt for the OEM coolant. There is a pump that you use to get the fluid up into the pan. Are you using a Bently manual? There are specific temperatures you are suppose to use when filling the pan.
EvoTillIDie1
Mar 5, 2014 10:42 PM
manindra
Feb 10, 2009 05:59 PM
SouthernAudi
Oct 14, 2007 06:47 PM
viper771
Mar 7, 2006 05:52 AM
