Newb: "SAFE" displays on Radio
Before you start to yell, I searched. I came up with the battery had recently been replaced, and needed a program code before using the radio, but myne is different (I havent had the battery replaced, and there are less than 5k miles on the car).
When I turn on my A4, it says SAFE on the radio and on the screen located on the dash. I read in the manual that this will happen if I am using the wrong key. I am using the correct key which starts the car fine. If I turn on the car, it will say SAFE, if I turn off the Radio, then I turn it back on... It will work. Is there a solution that will fix this?
Thanks
Thanks
It sounds like you have a loose connection to the radio's power somewhere, and you might want that checked out by a dealership. They can also tell you the code while they have the radio pulled out.
JonjonnyTT
Mar 15, 2015 01:21 PM
bmwtoaudi
Dec 9, 2006 03:42 PM
