Newb: "SAFE" displays on Radio
Old Aug 11, 2007 | 10:29 PM
jake123's Avatar
Default Newb: "SAFE" displays on Radio
Before you start to yell, I searched. I came up with the battery had recently been replaced, and needed a program code before using the radio, but myne is different (I havent had the battery replaced, and there are less than 5k miles on the car).
When I turn on my A4, it says SAFE on the radio and on the screen located on the dash. I read in the manual that this will happen if I am using the wrong key. I am using the correct key which starts the car fine. If I turn on the car, it will say SAFE, if I turn off the Radio, then I turn it back on... It will work. Is there a solution that will fix this?
Thanks
Old Aug 11, 2007 | 11:14 PM
genovese45's Avatar
Default RE: Newb: "SAFE" displays on Radio
go in your manual itshould have a codeand it will tell you exactly what to do and if you dont have the code you should call your local audi dealership..
Old Aug 11, 2007 | 11:29 PM
jake123's Avatar
I couldn't find the code. I am just worried about a Dension ipod dock I have built into the car, they may blame it on that and void the headunits warrenty.
Old Aug 12, 2007 | 07:55 AM
CLX's Avatar
CLX
Zombie Defense Force
It sounds like you have a loose connection to the radio's power somewhere, and you might want that checked out by a dealership. They can also tell you the code while they have the radio pulled out.
JonjonnyTT
Mar 15, 2015 01:21 PM
S4LIFE
Dec 28, 2006 10:52 PM
Sp33d07
Apr 19, 2006 08:32 PM
vitonxl
Jun 9, 2005 01:19 PM
