newbie cel question
Old Jan 30, 2006 | 02:54 PM
kmill58's Avatar
Default newbie cel question
i just purchased a vag-com,hooked it up and ran the program.
fault code 17536 came up.the code indacates fuel is to lean.
can this be corrected with the vag-com program from my lap top?
Old Jan 30, 2006 | 07:48 PM
david9999's Avatar
Default RE: newbie cel question
No, you need to find the probable vacuum leak. Check all you vacuum hoses and connections for cracks.
I am not at home, so I can't look up all the possible causes.
Old Jan 30, 2006 | 08:04 PM
techbod's Avatar
17536 - P1128 intake/exhaust leak, hose leak
Old Jan 30, 2006 | 11:07 PM
david9999's Avatar
Road test vehicle (fuel in oil).
- Check fuel system pressure Page 24-33
- Check Mass Air Flow (MAF) sensor Page 24-60
- Check intake system for leaks (false air) Page 24-68
P1128
17536
Bank 1, mixture adaptation (mult.)
System too lean
- Check oxygen sensor before catalytic converter Page 24-71
- Check oxygen sensor behind catalytic converter Page 24-87
- Check fuel injectors Page 24-38 .
Old Jan 31, 2006 | 01:22 AM
kmill58's Avatar
thanks for the info
freshlymade
Dec 31, 2008 09:22 AM
angeldunk707
Mar 27, 2008 11:36 AM
del23
May 7, 2007 04:36 PM
sandman512
Sep 22, 2005 09:12 PM
Nasalcrom
Jun 29, 2004 01:58 PM
