Nitrous set up, writeup
Old Oct 29, 2007 | 11:51 PM
oneg's Avatar
Default Nitrous set up, writeup
so today i final decided to put in the nitrous, i took pics as i went, so here they are. Its all strung up and together, i just need to run a few more electrical components tmrw and get the bottle filled. we tapped into he intake manifold between the throttle body and the maf, its all very hidden and almost completely unnoticeable except for a few extra braided lines peaking out.
under the back seat and along the passenger side plastic
only part of the hose you can see inside the car
into a vent and out into the wheel well
up and into a hole cut in the passenger side engine compartment
all the solenoids are hidden and behind the intake theres a purge in there too, ran out too the front through the middle of the Audi rings.
Old Oct 29, 2007 | 11:54 PM
apr_a4's Avatar
Default RE: Nitrous set up, writeup
congrats, cant wait to see vids!
nice job
Old Oct 29, 2007 | 11:56 PM
sean1.8t's Avatar
very nice. like to see the 2.8 guys get their hands diry
Old Oct 29, 2007 | 11:59 PM
cincyTT's Avatar
I'm make believe
Think you really should of ran the lineunder the car and not through it. But cant wait to see it run. SHould be a blast.
Old Oct 30, 2007 | 12:02 AM
oneg's Avatar
well its inside the plastic molding, took it all off and ran it through it. oh, and i got the service manual, fuel pump pressure its 46-54psi connected, if i rember correctly.
Old Oct 30, 2007 | 12:03 AM
hiwords's Avatar
wish i knew how to hook that thing up. i would def do it next summer if u do a full write up oneg
Old Oct 30, 2007 | 12:08 AM
oneg's Avatar
Whenyou get the kit and string the line into the engine compartment ill do a write up from there on . its pretty simple once you get into it, im just guna make sure everything goes smoothly in testing before i do a real write up.
Old Oct 30, 2007 | 12:09 AM
Bogie's Avatar
Nice job Geno. Did you say you put theNOS jet in before or after the MAF?
Old Oct 30, 2007 | 12:11 AM
oneg's Avatar
OHOH, one more thing, its set up so once i flip an arming switch, its ready, and when i push the peddle down too full throttle, it clicks on the nitrous and sprays it into the intake. so it goes on when the intake is full open and when the peddles floored, a little different from the push button setup i was going to run.
oneg's Avatar
ORIGINAL: Bogie
after
