No clutch = Timing belt job
Old Feb 4, 2008 | 12:19 PM
Papachristou's Avatar
Default No clutch = Timing belt job
well my clutch didnt make it from southbend[headbang] they had it week before last! i had my differential and tranny fluid 2nd day air'ed to me to make sure i got it all in since southbend assured me it would be in by friday.... so i figured i would tackle this timing belt job..
easy as can be except for mounting the belt of course.... all my marks are still lined up so i pray its ok! if not ill be quite pissed if my car sounds like a diesel when it starts as ive put a fair amount of work into it the past two weeks!
so here is my photograph journey!
boring i know, just headlights off
i was by myself (no one wants to be my friend when i need car help!)... not so fun
yeah ive beer working out
perks of being lowered[headbang]
this coolant was nasty! i have new g12 and distilled water!
ac condensor off.. be careful with the power steering cooler even though im fitting to junk it
lock carrier away! two man job! i didnt realize that until it pretty much fell off!
this stock intercooler is just downright crappy... my **** is longer than it! (and thicker too)
but all is still well. i have this to replace it! small one will be for power steering, im going to use AN barbs to replace the OEM cooler lines i believe
timing belt was PERFECT!!!! i have 77k and i run it hard... not a single crack, no leaking around the water pump or anything! i couldnt believe it! plus i have (well had) the plastic impeller water pump! new one is much better!
finally new timing belt installed......
i didnt button it back up because my serpentine adjustor pulley didnt spin very well so im going to go ahead and replace it.... all the other pulleys spun freely so i think ill leave them! although if its only $10-20 i might just replace the other roller pulley too
Now i just need my clutch so i can drive my car again![=(]
Old Feb 4, 2008 | 12:28 PM
CAB509's Avatar
6th Gear
Default RE: No clutch = Timing belt job
ORIGINAL: Papachristou
https://www.audiforums.com/upfiles/1...a321183163.jpg
[IMG]https://www.audiforums.com/upfiles/17720/asppg_Bu582176852.jpg
[/IMG]
A41.8T Owner
Oct 18, 2012 06:59 PM
Nevalite
Jul 30, 2012 11:52 AM
bmoore98A4
Jul 29, 2011 01:41 PM
Bartlett
May 7, 2008 04:34 PM
SourDieselS4
Sep 10, 2007 06:26 PM
