NO HEAT PLEASE HELP ITS COLD
Old Feb 13, 2007 | 06:54 PM
My A4's Avatar
Default NO HEAT PLEASE HELP ITS COLD
Hey Guys
my car has heating problems.... i live in canada and there times where it gets cold or colder anyways i drive 2.8 and i have replace all the sensors bleed the system no air in the system and flushed it twice even the heat core. when its on idle its blows cold air from the vents bottom top middlewhen i drive the car or rev high the heat will come out but its not blowing hot and one thing i notice that when i turn the climate control on and set it to HI the A/C comes on same times i am not two sure what going on i ahve done al sort ofsearch every where and before taking it to the dealer ship and pay arm and leg for them to dignos the problem thought i would ask here first.
any suggestions please its too COLD in CANADA
THANKS
Old Feb 13, 2007 | 09:16 PM
wood_e's Avatar
Default RE: HEAT
Hows your thermostat?
Old Feb 14, 2007 | 01:59 AM
My A4's Avatar
Default RE: HEAT
just replace it not long ago and also my temp gauge is good also the car get to it normal reach temp so there is no error codes ??????? i am so lost anyone
Old Feb 14, 2007 | 09:07 PM
CRAZYHAWK's Avatar
Default RE: HEAT
The doors in the vents might be stuck.
Old Feb 14, 2007 | 10:15 PM
A4nicator's Avatar
Default RE: HEAT
sounds like maybe your blower might be back? Did you check the heater core?
Old Feb 15, 2007 | 02:20 AM
My A4's Avatar
Default RE: HEAT
i got my heater core flushed still made no difference i will check the door
Old Feb 17, 2007 | 10:30 AM
david9999's Avatar
Default RE: HEAT
Have it run on a real vagcom and check the HVAC system for codes. There is also test procedures you can run with the vagcom. Sounds like a flap valve is stuck and air is not being directed over the heater core.
Old Feb 17, 2007 | 07:30 PM
tfische12's Avatar
Default RE: NO HEAT PLEASE HELP ITS COLD
I believe the AC comes on to control the humidity of the air so your windows dont fog up.
soltisb
Jan 24, 2013 09:26 PM
Dougs Red Audi
Apr 1, 2010 05:05 AM
PhilH930
Nov 27, 2007 11:37 PM
idice
Nov 30, 2005 10:08 PM
