No heat in the car Help is so dam cold
Old Nov 17, 2005 | 12:19 PM
idice's Avatar
Default No heat in the car Help is so dam cold
ok the winter is here and im trying to turn the hetter on but it seems that no heat is comeing in. i looked under the dash and the litel motors are turneing to open it. The car runs fine the coolant hose is hot that goes in the car so does the out one. what can it be the problem???? are there any other things i have to check??? o and the fuse its ok. i just cant figure it out.
Old Nov 17, 2005 | 03:53 PM
dankhound's Avatar
Default RE: No heat in the car Help is so dam cold
I suspect that the door that controls the airflow across the heater core is not operating or not operating properly.
Old Nov 18, 2005 | 08:57 PM
jkutt's Avatar
i am experencing the same thing in my 1995 A6 Audi. Please let me know what you find.
Old Nov 19, 2005 | 06:13 PM
tlstyle's Avatar
is your temp guage moving. you thermostat could be bad. if you hold it at like 2500 rpm and you get heat you probably have a flow problem somewhere. follow the hoses going to the heater core and see where it goes from hot to warm.
Old Nov 27, 2005 | 08:34 PM
gregp1962's Avatar
I'm having the same problem. The engine is making enough heat. I think it's the flap that controls the heat thru the core. Does anyone know how to manually move the flap?
Old Nov 30, 2005 | 10:08 PM
steviejayvaughan's Avatar
id check the heater control valve. it should be vacuum controlled. its under the cowl area. remove the plastic cowl trim and you'll see it where the two heater hoses go into the heater core. make sure your getting vacuum and the valve will hold vacuum itself.
soltisb
Jan 24, 2013 09:26 PM
Dougs Red Audi
Apr 1, 2010 05:05 AM
PhilH930
Nov 27, 2007 11:37 PM
My A4
Feb 17, 2007 07:30 PM
