No windsheild washer....
Old Feb 28, 2005 | 11:13 AM
Andrewuvm's Avatar
Default No windsheild washer....
Seems as though my windsheild washer system has died. I checked all of the fuses and nothing is blown.
It's a 04 1.8T with 40K miles on it.
Ant ideas? relays?
Thanks.
Old Feb 28, 2005 | 12:03 PM
Jestnomen's Avatar
6th Gear
Default RE: No windsheild washer....
probably a bad pump. You're under warranty, take it back!
When you turn on the winshield washers can you hear the pump? Any fluid on the ground?
Old Feb 28, 2005 | 01:55 PM
smythe's Avatar
Where do you live? Is it cold? If you put water or non temp rated washer fluid in your tank it will freeze. Check you fluid level and if it is frozen and make sure you buy fluid thats rated to -20C. locking the motor may or may not cause a fuse to blow but will definately will result in no fluid or sound from the motor.
You should be able to hear the relays if you turn ignition to second position without starting it and then hitting the wash switch.
Old Feb 28, 2005 | 04:00 PM
Andrewuvm's Avatar
I live in CT. It worked last Friday when we got the snow and then it just died. Thought maybe it was empty, but the warning light never came on. I use -30 washer so the freezing shouldn't be an issue.
I'll need to check if it is clogged, otherwise I think it is the pump that has gone bad.
Old Feb 28, 2005 | 05:26 PM
BaconBait's Avatar
I ran into a slight problem with snow and my fluid sprayers. Make sure you wipe the snow out from between the windshield and the sprayers.
Old Feb 28, 2005 | 07:25 PM
david9999's Avatar
Warranty time
Old Mar 1, 2005 | 07:41 AM
seohkim's Avatar
I had the same problem with me 2001 A4 at 60k miles. Mine problem was that there was a crack in the washer tank so I would put in the fluid and it would just slowly leak out. I didn't notice this was happening for a while, I though it was odd. I just looked under the car while pouring and I found it out. That could be the case. 40k in your car? It should still be in warrenty no? The dealer would take care of it. I though you get 50k warranty on the car.
Davidiot
Apr 16, 2015 11:37 AM
quattrojoe
Sep 11, 2012 01:02 AM
MartinCieslak1
Oct 21, 2010 08:30 AM
ckbkny
Aug 28, 2009 04:04 PM
skylinergtr
Mar 11, 2009 01:02 PM
