Noise from front end
Old Jul 19, 2004 | 07:39 PM
NJ01A4's Avatar
Default Noise from front end
Hey Guys,
2001 a4 6cyl
I'm getting a noise when I hit a bump.
Best way to describe it is it sounds like loose change.
Noise isn't that loud, only happens when I hit a bump.
Sounds like its coming from the driver side.
Any idea what this might be?
Control arm bushings?
Old Jul 19, 2004 | 09:24 PM
A4climb's Avatar
Default RE: Noise from front end
Sounds like the caliper..I had the same problem. I s it more a "clonk" or more metallic?
Mine was very metallic-like, and happened especially on small bumps.
Old Jul 19, 2004 | 11:53 PM
NJ01A4's Avatar
Definently more metallic.
Don't feel anything through the wheel, has not effected performance in anyway.
What goes on the caliper that results in this sound?
Anyway to check it to see if it's bad?
Old Jul 20, 2004 | 04:09 AM
brrman's Avatar
make sure you don;t have loose change in your pocket.
Doesn;t sound like a ball joint.. that would be more of a clunking.
abarmard
Nov 17, 2013 01:39 PM
Hitchr10
Mar 14, 2008 05:59 PM
hoovis
Aug 24, 2006 01:42 PM
Chad021179
Feb 7, 2005 09:13 PM
