Is it normal
Old Jan 24, 2008 | 04:44 PM
tatensty's Avatar
Member
Default Is it normal
I have a 2000 a4q 5sp. I noticed that when i do have my car in gear and i turn my steering wheel that my rpms change slightly and i think thats sort of strange and wanted to know if that is normal.
Old Jan 24, 2008 | 04:51 PM
cincyTT's Avatar
I'm make believe
Default RE: Is it normal
thats not normal. You may need a tb alignment
Old Jan 24, 2008 | 04:55 PM
tatensty's Avatar
Member
Thanks, didn't think it was. Any chance you could tell me how much they charge for that also can they do they when i get my alignment fixed
Old Jan 24, 2008 | 05:04 PM
cincyTT's Avatar
I'm make believe
just undo the battery for about 10mins and then reinstall it. Then turn the key to on and dont start it. You will hear a buzzing, when its done, you are done.
Old Jan 24, 2008 | 05:11 PM
brrman's Avatar
RPMs can studder slightly if your power steering pump is low on fluid or has dirty fluid.
tatensty's Avatar
Member
bad *** good lookin out when the rain leaves i'll give ago
Old Jan 24, 2008 | 07:11 PM
dankhound's Avatar
The rpms should go up when power steering is all the way to one side. That puts an extra load on the engine at idle that needs to be compensated for. I wouldnt worry to much about it.
Old Jan 24, 2008 | 09:06 PM
auditech79's Avatar
ORIGINAL: dankhound
Exactly, the fluid might be a bit low because its a mineral based fluid which evaporates over time. Just top it off and you should be good to go.
Old Jan 24, 2008 | 09:14 PM
FASTER's Avatar
Tech Slut
defintly normal... any belt driven pump or accessory pulls power from the motor...
Nevalite
Apr 23, 2010 11:39 PM
sirminder
Aug 13, 2009 11:08 PM
P.O.S._for_today
Jun 4, 2009 07:21 PM
Bklynrx7
Apr 21, 2009 12:55 PM
Brandon2000s4
Jul 20, 2007 06:44 PM
