not thinkin this is good...
Old Jan 9, 2008 | 01:24 PM
veloracer's Avatar
Default RE: not thinkin this is good...
The seafoam will clean out all the gunk in the engine. There's lots of write-ups on how to sea-foam your car. Just search.
If for some reason your engine seizes up due to oil sludge, AOA might replace the engine for you, at their discretion. You need to keep all your oil change receipts as proof that you have been using AOA-approved synthetic oils in your engine at regular intervals. You can ask auditech79 about the oil sludge warranty. He can explain it much better.
Old Jan 9, 2008 | 01:56 PM
dafowler88's Avatar
Drain oldoil...upgrade to larger filter like ison the '05 B6...put newoil back in.
Experiencing any performance issues?
Old Jan 9, 2008 | 02:14 PM
rbrtech's Avatar
its not much to worry about its condensation building up. Clean the cap see if it returns
Old Jan 9, 2008 | 04:20 PM
CRAZYHAWK's Avatar
I think the sludge warranty is only for 1.8t.
You should add 1 1/2 oz of Seafoam for every quart of oil.
Drive around 75mi. Change the oil and filter.
Old Jan 9, 2008 | 06:26 PM
TorsenTaxi's Avatar
Duburban had it 1st, when I first read the question I wondered whereCoBra03 lived. I too live in upstate NY, and yup that really is just the weather. If you don't get the oil up to 212°F the water doesn't boil off. After repeated short trips with a sub-212°F oil you'll accumulate enough water so that it can begin emulsifying, which is that cream colored foam in the photos. Even synthetic oil will do it, although to a lesser extent.
By all means change the oil to your preference, clean the cap, and keep an eye on it. That means everyday for a week or so. If you see traces of emulsified oil, take the car for a ride into the hills, put some heat into the engine, get your oil hot. Open the cap when you get home and the oil should be clear again. The more you let accumulate the longer you need to drive the car to boil the water off.My2.8 used to need a nice 90 minute cruise every couple of weeks in the winter to stay clean. It won't happen in the summer. I haven't seen any on the 2.0, (I've only had it 3 weeks)but I should look (thanks for the reminder).
Think of it as, just one of those wonderful added benefits to living in the great white north (no white at the moment).
Old Jan 9, 2008 | 10:30 PM
CoBra03TerminAtoR's Avatar
alright, thanks for the help guys... i plan on changin the oil this weekend... will the b6 oil filter work on my car? and can i add the sea foam to my engine right now? then just change the oil this weekend? thanks again...
Old Jan 9, 2008 | 11:27 PM
dafowler88's Avatar
ORIGINAL: CoBra03TerminAtoR
I thought you did drive a B6....?
Old Jan 10, 2008 | 08:22 AM
  #18
its an 03, i thought that mine was a b5?
Old Jan 10, 2008 | 08:41 AM
  #19
woops i guess mine is a b6 ha sorry, brain fart...
Old Jan 10, 2008 | 10:04 AM
  #20
CRAZYHAWK's Avatar
You can add Seafoam 50 to 75 mi. before changing the oil.
