o2 sensor help
Old Sep 13, 2005 | 11:56 PM
flyinb501's Avatar
Default o2 sensor help
I just changed my spark plugs and was about to replace the o2 sensors. Well the Haynes manual is worthless on this subject. Does anyone have a write up on doing this. How do you get to the pre cat sensor. I thought about taking the airbox off but I'm not sure that it will really help at all. Also, I assume you have to use a wrench to get it off. There's just not that much room down there.
Old Sep 14, 2005 | 01:48 AM
flyinb501's Avatar
Default RE: o2 sensor help
Anybody?
Old Sep 14, 2005 | 01:52 AM
black b5's Avatar
i was able to remove mine easily with a wrench while my air box was removed.
i think you could get at it with a o2 sensor socket and not need to remove the air box.
not a whole lot of help but this is what i know
Old Sep 14, 2005 | 02:14 AM
flyinb501's Avatar
No, thats actually very helpfull. Is an o2 sensor socket pretty common, like could I get it somewhere like Autozone? I assume its just a longer socket w/ a slot to accomodate for the wires.
Old Sep 14, 2005 | 03:16 AM
flyinb501's Avatar
Alright, I just ordered an o2 sensor socket off ebay so I'm all set.
Old Sep 14, 2005 | 03:37 AM
CRAZYHAWK's Avatar
You should remove the antifreeze reservoir screws. The O2 sensor unplugs below it.
Old Sep 14, 2005 | 04:03 AM
flyinb501's Avatar
Yeah, I know that's where it plugs. I'm talkin about the actual sensor.
Old Sep 14, 2005 | 07:49 PM
dafrazi's Avatar
i took the air box out when I pulled the precat O2 sensor out. You don't need to but it made it easier.
The post cat sensor is a real PITA. You need to access it from the bottom of the car and there really isn't any room where it's located.
Old Sep 14, 2005 | 11:35 PM
flyinb501's Avatar
Oh great, I haven't even got under there to check that one out yet. Hopefully I won't have any problems with it.
neomaxddr
Apr 1, 2009 03:16 AM
