Oil Change 1.8T
Old Oct 25, 2007 | 07:02 PM
cantdrive55's Avatar
Default Oil Change 1.8T
So instead of taking it someplace to get the oil changed I plan on a DIY this weekend. I'm gonna use 5W-40 Mobil1 but as far as the filter goes, I'm seeing these ones:
Mobil1 -
M1301
K&N -
HP3001
Bosch -
72211
Then for the drain plug I'm not sure if I have a M26-1.50 or a M14-1.50. I've seen both. So which filter should I look at getting or should I just get one of the kits from ECS?
Old Oct 25, 2007 | 07:39 PM
auditech79's Avatar
Default RE: Oil Change 1.8T
Best to get a Mann or Mahle filter from ECS tuning, they are just as good as the factory filters.
Whatever you do, don't put a FRAM filter on. [:'(]
Old Oct 25, 2007 | 08:03 PM
apr_a4's Avatar
if you can afford it get amsoil european synthetic blend
its worth it they provide the best protection and service intervals arent as small
Old Oct 25, 2007 | 08:41 PM
Ok. I just found out that I've got to go relatively close to the local Audi dealer. Think I should just get the parts there or are they gonna make my wallet feel lighter than it should?
Old Oct 25, 2007 | 08:42 PM
veloracer's Avatar
If you're going to buy the OEM filter, I suggest you buy from a VW dealer, not an Audi dealer. It will be cheaper at VW.
Old Oct 25, 2007 | 08:45 PM
Trey25's Avatar
Use the mobil1 filter. Its a microfiber filter unlike the ordinary paper filters, plus its a larger diamter. Valvoline, mobil1 or amsoil are all good choices.
Old Oct 25, 2007 | 08:47 PM
onepoint8tee's Avatar
You can getyour oil and a Mobil 1 oil filterwhich is the updated larger sizefrom adavance auto parts or autozone. Youll pay less anywhere other than the dealer for sure. Parts from any dealer are insanely marked up.
Old Oct 26, 2007 | 02:15 PM
jonsaudi's Avatar
Yeah. If you'd go to a dealer, I would go w/ VW. For some absurd reason, VW charges less than Audi for the same flippin' part!?!? Ex/ a gallon of coolant, $32.00 from Audi, same part; VW's $23.00. go figure.
Old Oct 26, 2007 | 04:21 PM
outasflyguy's Avatar
can someone explain to me exactly why the Fram filter is [:'(]?
Old Oct 26, 2007 | 04:46 PM
cincyTT's Avatar
I'm make believe
frams filtration is lower than others. Not sure how the higher cost ones are, but the basic filter is so so.
