Oil Change - Noob Question
Old Sep 28, 2007 | 09:43 AM
ballswell's Avatar
Default Oil Change - Noob Question
I had my oil changed, how do I reset the milage on the digital gage in the dash? Sorry for asking such a narrow question--I didn't get a book with my car
Thanks
Old Sep 28, 2007 | 11:07 AM
FASTER's Avatar
Tech Slut
Default RE: Oil Change - Noob Question
u talking about the tipometer? just press the little post
Old Sep 28, 2007 | 11:56 AM
akielb's Avatar
that depends on your year -
go to audidiy.com - and scroll down the service interval light reset - and select your year
Old Sep 28, 2007 | 12:28 PM
TDRILL's Avatar
Ha ha, this question rocks!
Yea man, you need to always post what car you have so model changes can be noted. Just put it in your signature so its always posted.
B5s, you push that stalk protruding from the dashboard (right near the trip display). You know just like on almost every other car in the world.
You should get a manual. There is a ton of stuff in there. Audis come with a lot of features plus you will have to ask about a lot of silly stuff if you can't clear warning lights or input a radio code or anything.
Old Sep 28, 2007 | 03:12 PM
qUaTtRoA4's Avatar
if it's a 98 or 99
[ol][*]Insert your key into the ignition.[*]Push in the odometer reset button, hold it in, and turn the key to the first click.[*]The display should read either "oil" or "service" if it does not, repeat steps #1 and #2.[*]To reset, pull out your instrument light dimmer button at the bottom of the tachometer.[*]Turn the ignition to the off position. When the ignition is turned back on, the display should be back to the trip odometer. [/ol]
Hendrixio
Mar 24, 2011 11:37 PM
batoloco666
Sep 1, 2010 02:59 PM
ard
Mar 15, 2009 03:18 PM
onefasts4
Apr 30, 2007 10:28 PM
ricehead
Sep 8, 2005 01:14 PM
