Oil drain plug stripped
Old Nov 15, 2007 | 11:09 PM
SAudi's Avatar
Default Oil drain plug stripped
well today while changing the oil the drain plug stripped, really bad, coulndt get it off, took to two different places and they couldnt do anything, and told me the only real thing i could do is replace the whole oil pan, does this sound like BS or can i do something about it.
Old Nov 15, 2007 | 11:11 PM
Chill72's Avatar
Member
Default RE: Oil drain plug stripped
Get some channel locks and take it off.
Make sure you got a replacement on hand.
Old Nov 15, 2007 | 11:16 PM
cincyTT's Avatar
I'm make believe
Yep, sounds about right. You can either helicoil (sp?) the pan or replace the whole pan. Those are your only options.
Old Nov 15, 2007 | 11:49 PM
SAudi's Avatar
well i tried to use achannle lock andvisegrop but that didnt reallt work and the bolt is pretty much over tightened, what would the helicoil tool do.
Old Nov 16, 2007 | 12:03 AM
hiwords's Avatar
it's not a tool. it's like a spring that fits snugly in the hole and u put a plug in to fill the hole. so it's like a manmade thread so to speak
Old Nov 16, 2007 | 12:08 AM
Bogie's Avatar
Ahelicoil is used if the threads are stripped out of the pan - you know - the drain plug turns but won't back out.If you stripped the head of the bolt, just weld a shitty socket to the drain plug and TAKE IT OUT. And of course, replace it with a new one.
hottubbrad
Dec 16, 2009 11:24 PM
jakej
Oct 3, 2008 12:42 AM
thak
May 16, 2007 03:23 PM
jonny29
Feb 21, 2007 03:01 AM
werkwitdis
Jun 4, 2006 02:07 AM
