Oil engine problems A4 year 2000
Old Jan 28, 2005 | 02:58 PM
phil's Avatar
Default Oil engine problems A4 year 2000
Help...
My friend has an Audi A4 1.8 turbo. and the engine has stopped due to the oil sludge problem.
Audi is refusing to fix it because they do not accept his "oil change" receipts (most are from a regular shop...but two or three were done by a relative who is a licensed mechanic)..
Has anyone had similar experience with Audi wanting to avoid their responsibility to fix this?
The car has 51,000 mi.
Thanks, Phil
Old Jan 28, 2005 | 04:17 PM
clconversion's Avatar
Default RE: Oil engine problems A4 year 2000
yes this I have seen in the technicaial bulliten if the correct maintance has not been performed by a Audi dealer Audi can refuse this could be your friend not using the recommened oil if he has recipts for the oil that he had used he can try that i'm not sure and also should be a factory oil filter that was used when the service was done
Old Jan 28, 2005 | 06:40 PM
TripN's Avatar
What is an oil sludge problem? I have seen that work being used alot in these forumns.
How is one to prevent it?
Old Jan 28, 2005 | 07:04 PM
oil sludge is just as it says oil sludge oil build up the way to prevent it is to use syntetic oil and the new bigger oil filter part #068115561B
Old Jan 29, 2005 | 09:13 PM
david9999's Avatar
Not true. If you have evidence of oil changes done at the recommended intervals by anyone you should be OK. But, if you had it done by a friend and have no record of the service being done, then you are at their mercy.
E_Romero125
Oct 5, 2014 05:01 PM
willythecat
Aug 16, 2013 08:03 PM
jenniferk
Oct 29, 2008 11:43 PM
CTDriver
Mar 21, 2008 04:08 AM
efriedla
Dec 12, 2007 07:50 PM
