Sponsored by:
Sponsored by:
Oil filter on 06 Audi A4 2.0T
Old 10-15-2006, 11:30 PM
vmaxie's Avatar
Default Oil filter on 06 Audi A4 2.0T
Does anyone know where the oil filter on the 06 Audi A4 2.0T engine is located? I believe its the cannister type with a changeable element. Is it difficult to get to? Thxs
Old 10-21-2006, 02:21 PM
dankhound's Avatar
Default RE: Oil filter on 06 Audi A4 2.0T
Its on the drivers side of the block. Same location as the 1.8 filter. It is indeed a canister style. You can reach it from the bottom. There is a cap on the end that you unscrew. The housing has a 36mm socket end. Could be a 34mm. If its not on to tight you can use a large wrench to unscrew it. You may also need to disconnect the electrical connector on the engine mount. Its kinda in the way. All in all its in a pretty wide open spot thou. Also make sure you remove the oil fill cap before you drain the oil or else it will drain very slowly.
A4 Jed
06-23-2013 06:13 PM
milan2k12
04-23-2012 08:30 AM
elburko91
03-22-2011 07:27 PM
Niclipse
02-09-2009 01:39 AM
Quick Reply: Oil filter on 06 Audi A4 2.0T
