oil in fmic and pipes
Old Jan 5, 2008 | 01:13 PM
blackb5's Avatar
Default oil in fmic and pipes
ok i was cleaning the engine bay today, so i decided to take apart the pipes for the fmic. i then noticed that there was oil in the fmic and in the pipes. also there was oil in the pipes on the driver side of the fmic. i put the fmic up right to drain the oil out into a cup and 1/4 of oil was in the cup. is this normal??and where is this oil coming from?? i have a k04 installed last year, with the fmic and custom pipes.any help would be great
Old Jan 5, 2008 | 01:18 PM
cincyTT's Avatar
I'm make believe
Default RE: oil in fmic and pipes
The oil is blow by from the PCV. You need to add in a catch can to prevent this from happening. What a catch can will do is slow down the air before going into the intake and draw the oil out. A simple air compressor filter, some fittings and hose and you can have a really nice system for ~$30 and just a trip to Home Depot/Lowes and stop at the autoparts store
Old Jan 5, 2008 | 01:21 PM
blackb5's Avatar
oh i forgot to add that i have a catch can installed as well. so i cant really understand why there would be that much oil...
Old Jan 5, 2008 | 01:41 PM
cincyTT's Avatar
I'm make believe
let me guess, an empty ebay tank?
Old Jan 5, 2008 | 02:27 PM
blackb5's Avatar
actually i got the ATP turbo catch can
Old Jan 5, 2008 | 04:57 PM
auditech79's Avatar
Well did you ever check to see if the catch can is full? Are you still running the stock PCV valve too? If you are, change the PCV valve and empty the catch can.
mrbillmartin
Apr 1, 2014 09:43 AM
MauroB6
Nov 4, 2011 11:20 PM
jakgtrey
May 20, 2008 11:02 PM
SAudi
Mar 22, 2007 04:51 PM
mikejda
Dec 24, 2006 08:44 PM
