oil light
My Audi A4, 2005, has been consuming at least a quart of oil every 2K miles.The oil light usually comes on within a month after an oil change. When i first brought it in, they said that the sensors are just sensitive but it clearly was burning more oil than before. This seems excessive to me but the dealership did a bunch of tests (after having to bring it back several times) and told me that this was within spec'. The last time i brought it in, they told me to just top it off and refused to look any further. Does anyone else have a car that burns up that much oil? Doesn't seem right to me. If this is normal for Audis, something is wrong with these engines!
wow, quick reply...thanx. It's a 2.0. They checked quite a bit of things, like the pistons, plugs, oil consuption, etc, then told me it was "normal" since they couldn't find anything. They even replaced the Turbo twice.
Jesus what hack shop are you taking this to? Just tell them to replace the PCV valve, since they can't prove that its bad it probably won't be under warranty, so just buy one.
I can't believe they replaced the turbo twice, thats stupid.
ORIGINAL: UpstateNYA4
Not trying to threadjack, but have you heard of a similar situation on the 30v engine? Mine seems to consume as well - more than I would expect.
mannyg_87
Feb 23, 2015 03:08 PM
crazybk187
Aug 5, 2013 04:29 PM
Pbcrazy
Sep 7, 2012 04:25 PM
