oil light came on, engine starting clicking
Old Oct 7, 2007 | 03:17 PM
onepoint8tee's Avatar
Default RE: oil light came on, engine starting clicking
Depends on their schedule. Probably not quite $1000, but more than $500.
Old Oct 7, 2007 | 05:46 PM
hollisterrobsta's Avatar
Had the same problem on my 1998.5 1.8t Quattro. Even after an oil change it would not go away, so I tried a last DIY attempt to try and save some money before taking it in to a mechanic. Getan motor/oil flush or seafoam from (insert favorite auto parts store here), dump it in your oil, let your car idle for like 5-10 minutes (DON'T DRIVE IT, your oil will be thin at this point)shut off wait, do oil change with FULL synthetic.I used someoil flush made for turbo'd carsthat they sold at NAPA, and changed it with Mobil 1.Stopped my ticking and turned off my oil check light. (the red one). IF it is sludge and you do the oil flush, youll notice a looooot of black stuff coming out when you do the oil change.
Old Oct 7, 2007 | 05:53 PM
auditech79's Avatar
This all depends on what engine you have really, 2.8L = bad oil pump 1.8T = oil pick up tube.
Either way they are both expensive but the 2.8L will have less labor time but more cost of the oil pump, 1.8T will have more labor but cheaper parts.
Both should equal around $800 at the dealer.
Old Oct 7, 2007 | 06:49 PM
david9999's Avatar
Audi of America has an extended "warranty" on oil pickup screen plugging due to sludge IF you can show that you have changed the oil every 5K miles. Start digging up your receipts. If your engine is making noise, I would not start it up again, have it flatbedded to a dealer for diagnosis and start collecting your service receipts.
michaelmcgo
Aug 22, 2013 12:22 PM
aramkim
Feb 11, 2008 05:12 PM
rob1234
Oct 4, 2006 05:14 PM
prestonthomson
Jun 27, 2006 07:03 PM
dlinbh
Dec 8, 2005 11:34 PM
