Oil Pan removal
Old Sep 23, 2007 | 06:52 PM
The Russian's Avatar
Default Oil Pan removal
Hey so i got some cracks in that oilpan of mine now. how hard is it to pull the oil pan? becase it looks like i would have to drop lower pars (krossmember and such), has anyone done it?
Old Sep 23, 2007 | 07:01 PM
auditech79's Avatar
Default RE: Oil Pan removal
Its a PITA on a 1.8T, you have to lower the subframe while either using a support tool to hold the motor up or use a jack on the trans to get enough room to remove the pan.
Old Sep 23, 2007 | 07:37 PM
i think i am just gonna drain the oil out nd clean p the surface of the pan with partswash and some scratch pards or somethign and just JB weld it http://jbweld.net/products/water.php talked to some peopl and they said that that stuff works great for oilpans.... would save me a lot of work time and money... and sh*t, i just need somethign to hold my oil... i dont' care if it looks good or not
onepoint8tee's Avatar
Weld er
Old Sep 23, 2007 | 07:44 PM
that was the initial plan, but it woudl be a pain to pull the pan, and i don't want to weld it on the car even with the oil drained
Old Sep 23, 2007 | 07:45 PM
auditech79's Avatar
Especially when it comes time to change the oil pick up tube.
Old Sep 23, 2007 | 07:54 PM
Well ya dont weld where the pan is bolted to the block. If it was a crack on the bottom it would work.
Might be a good idea to get an in cabin oil pressure gauge if youre going to be thrashing the car all the timewithout a beefy belly pan [8D]
Soley4pres
Jul 11, 2011 11:58 PM
99a4wagon
Dec 10, 2010 07:03 PM
halfmoonclip
B8 Models
Jan 9, 2010 09:48 PM
nhltfour
Apr 22, 2007 02:23 AM
MeanAudiA6
Aug 6, 2006 04:57 PM
