Oil question 2.8
I did my oil change the other day and went from Mobile1 10w30 to Royal Purple 5w30.Before, after sitting for a few hours it would have a little valve tap for about a second then go away. Now it does it after sitting for about 10 minutes and it's louder. Should I go to a thicker oil? The oil temp is also running higher than the previous weight oil. I'm driving to Oregon Friday and will be putting about 1,000 miles on the car.
I use Aimsoil 5W-40 euroblend and I don't seem to have a problem. I can't think of why it would be a problem to run a 5w-30 because the high weight is still the same. I don' know much to anything about oil's and how there made but I wouldn't think there would be a problem because of it.
I'm just curious because now with the 5w30 the oil runs hotter (1 bar higher on the gauge) and the rockers clack for a second or 2 after only sitting for about 10-15 minutes where as before it would only do it after sitting for a few hours. I'm thinking the thinner oil is leaving the head faster but there again, I'm not an oil expert.
Royal Purple is a true full synthetic so it is gonna be a bit thinner but trust me your not gonna damage your engine with using that oil, now it may leak a little bit more now because synthetic can find its way out of old seals easier than a heavier oil.
akitamike
Jun 9, 2008 11:05 AM
SouthernAudi
Oct 14, 2007 06:47 PM
