Oil question 2.8
Old Aug 30, 2007 | 12:03 AM
LowA4's Avatar
Default Oil question 2.8
I did my oil change the other day and went from Mobile1 10w30 to Royal Purple 5w30.Before, after sitting for a few hours it would have a little valve tap for about a second then go away. Now it does it after sitting for about 10 minutes and it's louder. Should I go to a thicker oil? The oil temp is also running higher than the previous weight oil. I'm driving to Oregon Friday and will be putting about 1,000 miles on the car.
Old Aug 30, 2007 | 02:27 PM
LowA4's Avatar
Default RE: Oil question 2.8
It's been between 90-100* up here and I drive a steep grade everyday.
Old Aug 30, 2007 | 02:44 PM
CAB509's Avatar
6th Gear
I use Aimsoil 5W-40 euroblend and I don't seem to have a problem. I can't think of why it would be a problem to run a 5w-30 because the high weight is still the same. I don' know much to anything about oil's and how there made but I wouldn't think there would be a problem because of it.
Old Aug 30, 2007 | 02:50 PM
auditech79's Avatar
You'll be fine, switching weights won't really affect the motor as much as you think, Royal Purple is a much better oil anyway just run it the tapping should go away.
Old Aug 30, 2007 | 02:53 PM
LowA4's Avatar
I'm just curious because now with the 5w30 the oil runs hotter (1 bar higher on the gauge) and the rockers clack for a second or 2 after only sitting for about 10-15 minutes where as before it would only do it after sitting for a few hours. I'm thinking the thinner oil is leaving the head faster but there again, I'm not an oil expert.
Old Aug 30, 2007 | 02:54 PM
LowA4's Avatar
It goes away after a second or 2. I just hate that sound.
Old Aug 30, 2007 | 03:03 PM
auditech79's Avatar
Royal Purple is a true full synthetic so it is gonna be a bit thinner but trust me your not gonna damage your engine with using that oil, now it may leak a little bit more now because synthetic can find its way out of old seals easier than a heavier oil.
EvoTillIDie1
Mar 5, 2014 10:42 PM
manindra
Feb 10, 2009 05:59 PM
SouthernAudi
Oct 14, 2007 06:47 PM
viper771
Mar 7, 2006 05:52 AM
