Oil sensor
Old Apr 1, 2007 | 06:34 PM
fcanozo's Avatar
Default Oil sensor
Hi guys, My oil sensor light is on for few min and then off and on again. Any body know what it means? How to fix it?
Thanks.
Old Apr 1, 2007 | 06:44 PM
speedracer52's Avatar
Default RE: Oil sensor
Low oil. My suburban does that too though even though i just took it in that is really annoying.
Old Apr 1, 2007 | 06:50 PM
fcanozo's Avatar
ok, thank you I thought was something else
Old Apr 1, 2007 | 08:09 PM
david9999's Avatar
How about low oil pressure reading.
Either of the following.
1. Low oil level.
2. Engine Sludge
3. Bad sensor.
Old Apr 1, 2007 | 08:44 PM
wood_e's Avatar
ORIGINAL: speedracer52
BUZZZZZ WRONG!
Listen to david....
Old Apr 6, 2007 | 04:36 AM
fcanozo's Avatar
When the light is on the gauge for temp. stop working what is it? sensor or what?
Old Apr 6, 2007 | 04:58 AM
fcanozo's Avatar
anybody?
Old Apr 6, 2007 | 05:01 AM
onepoint8tee's Avatar
Are you talking about the red OIL light?
Old Apr 6, 2007 | 10:19 AM
david9999's Avatar
Either your sensor is bad, you have very low oil, or very low oil pressure.
Check your oil level, if it is OK, then that isn't the problem.
If the light is now off, drive the car gently to a trusted mechanic and have him check the oil pressure. If the oil pressure is well within specs then have the sensor replaced.
If the oil pressure light is on, do not drive the car but have it towed to your mechanic. Low oil pressure and driving don't mix.
Old Apr 6, 2007 | 12:08 PM
fcanozo's Avatar
is the yellow light that say sensor and the oli level is good
neomaxddr
Apr 1, 2009 03:16 AM
