Ok im buying a gt28rs
Old Oct 22, 2007 | 09:45 PM
  #31
A4speed's Avatar
Default RE: Ok im buying a gt28rs
depends on if your sw changes your max rev. limit.
Old Oct 22, 2007 | 09:48 PM
  #32
chaos92287's Avatar
if you get it up to 150 you will be about redlining it.
oh and look into unitronics for sw.
Old Oct 22, 2007 | 09:50 PM
  #33
Kyle09's Avatar
ORIGINAL: A4speed
I know but say im going 80 in 5 gear and im at4000 rpm- That is stock turbo & everything else
So i get the new turbo, and i hit 80 in 5th gear---Will i be at4000 rpms like the stock turbo, or will i be at like 3000 rpm because of the new turbo..
-If only our cars had a 6th gear..if only
Old Oct 22, 2007 | 10:04 PM
  #34
Bogie's Avatar
anyone know what a 6 speed would cost and if it is a direct replacement for a 97-02 a4 5spd? clutch or anything else different? 6th is a different (lower ratio) than 5 (in a speed) is, right? if it is, you'll pick up top speed.
Old Oct 22, 2007 | 10:06 PM
  #35
Belligerenceā„¢'s Avatar
ORIGINAL: Kyle09
ORIGINAL: A4speed
no, your new turbo will not change your gear ratios...
Old Oct 22, 2007 | 10:18 PM
  #36
chaos92287's Avatar
ORIGINAL: Kyle09
ORIGINAL: A4speed
good question. i dunno actually. im thinkin since the gear ratio's are the same you should be at the same speed for a certain rpm. but if your at 80 and 4000 rpms i can't see it gaining another 70 mph in only 3k higher. i think my car is around 3-3.5k at 80 so maybe it is different. hopefully someone smart will chime in lol
Old Oct 22, 2007 | 10:30 PM
  #37
Kyle09's Avatar
Yeah i think that because the gear ratio is the same my top speed wont be any different.....does any one know if i am right? I should just get to the top speed faster..
cincyTT/auditech79/sean1.8T...HELP!
Old Oct 22, 2007 | 10:34 PM
  #38
^^correct. your top speed as it is determined by the gearing of the car will not change. your actual achievable top speed will increase, with the added power.
Old Oct 22, 2007 | 10:38 PM
  #39
AudiCross's Avatar
YES! your top speed will be teh same!!!! if you dont change your tranny, and you dont change your wheels, and you dont change your rev-limiter, your top speed will be the same.
in that pic he is at 106 mph while at 4.8k rpm. with simple math we see that the 7200 revlimiter when chipped, your speed will be 159 miles an hour at revlimiter assuming you have teh horsepower to get there. the revlimiter MAY be at 7300 rpm, which would make your top speed 161 mph
PLEASE! dont be retarded. unless you are on the fu(kin autobond or a long a$$ stright road like highway 80 going through the nevada desert, DONT DO IT
Old Oct 22, 2007 | 10:41 PM
  #40
hiwords's Avatar
like some ppl have been saying u have to change ur gear ratios for hgher top speed. i kno i saw a honda that was made into a 6 speed by adding a gear sumhow. it was in a magazine a while ago. maybe we can do the same thing? not sure though
